[Qgis-user] Building QGIS 1.0.0 on RHEL4 x86-64
Juha Tuomala Juha.Tuomala at iki.fi
Thu Apr 16 12:44:32 PDT 2009
On Thursday 16 April 2009 22:02:36 paulo.estrela at petrobras.com.br wrote:
> I built all qgis dependencies including qt4 for rhel4. I got the sources
> (version 4.4.2) from www.qtsoftware.com and installed them in
> /usr/local/qt4. I cannot change to Fedora because my clients use some
> proprietary geological interpretation software. As a test I will try
> Fedora...
In such case, you could try to get src rpms for all required packages
with yumdownloader tool which is included in yum-utils package. Once
you have them, you can build them with rpmbuild which comes from
rpm-build package. If they all build, you could put them into repo
with createrepo and then manage all clients with yum.
Manually building them more than one host is going to be time
consuming.
Tuju
Varo hattupƤisiƤ autoilijoita.
