[Qgis-user] Project takes very long to load
    Andreas Neumann
    a.neumann at carto.net
    Tue Apr 28 01:14:15 PDT 2009
Hello,
I'd like to inform you that Jürgen provided a fix for the problem, which
is now in trunk. Thank you Jürgen!
The problem really was the primary key detection, which was checked with
every project load and took very long for complex views/tables. Now the
pkey check is done with the initial layer loading and stored in the
project file. When loading the layer it seems like it first starts the
primary key detection with the stored key attribute from the project files
and stops searching for further keys after it confirmed that the suggested
key works - at least this is how I understand the current behavior in
trunk - Jürgen - please correct me if I am wrong.
Anyway - the project that previously loaded in 3-4 minutes now loads in
approx. 10 seconds.
I hope that this can still make it into the 1.1 release, as this is a big
problem for people with more complex tables/views.
Thanks,
Andreas
On Fri, April 24, 2009 10:59 am, Paolo Cavallini wrote:
> Andreas Neumann ha scritto:
>> Here is what I did so far:
>> I saved the project as a different name. So far this did not speed
>> things
>> up. I did a project file comparison in the OxygenXML editor. There are
>> only minor differences, like
> Very detailed report, thanks a lot Andreas!
> Hopefully jef will be able to understand what's going on.
> If I can help with testing, just let me know.
> All the best.
> Paolo Cavallini: http://www.faunalia.it/pc
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
