[Qgis-user] Project takes very long to load
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Tue Apr 28 03:08:52 PDT 2009
Andreas:
> I'd like to inform you that Jürgen provided a fix for the problem, which
> is now in trunk. Thank you Jürgen!
> The problem really was the primary key detection, which was checked with
> every project load and took very long for complex views/tables. Now the
> pkey check is done with the initial layer loading and stored in the
> project file. When loading the layer it seems like it first starts the
> primary key detection with the stored key attribute from the project files
> and stops searching for further keys after it confirmed that the suggested
> key works - at least this is how I understand the current behavior in
> trunk - Jürgen - please correct me if I am wrong.
> Anyway - the project that previously loaded in 3-4 minutes now loads in
> approx. 10 seconds.
Hi Andreas,
I just recompiled qgis_unstable. Unfortunately for me it doesn't improve
load time of old(er) projects.
Nikos
Ubuntu Jaunty 64-bit
