[Qgis-user] Project takes very long to load
Andreas Neumann
a.neumann at carto.net
Tue Apr 28 04:12:50 PDT 2009
Nikos,
As far as I know the improvements only cover Postgis layers - is this
correct, Jürgen?
Andreas
On Tue, April 28, 2009 12:40 pm, Nikos Alexandris wrote:
> Juergen, Andreas,
> Andreas:
>> Did you re-save the project in another name or saved it again?
> I loaded (waiting... watiting...), saved with a "_pan_1.1.qgs" suffix,
> closed and re-openned the project. It still takes _too_ much.
> But, it might be (also) another issue? This project loads a grass-raster
> rgb composite (20888276 cell count for _each_ band) and gives in the
> terminal some Warnings [1].
>> In any case, I would open the project file in a text/XML editor and make
>> sure that the key='gid' (or similar column name) is present in the
>> datasource element.
> I just searched in my *_pan_1.1.qgs files and there is not a single
> "key" string.
>> Here is an example:
>> <datasource>dbname='world' host=localhost port=5432 user='an'
>> sslmode=disable key='gid' table="countries"."country_border" (the_geom)
>> sql=</datasource>
>> Maybe you need to manually introduce the key='somekey' in a text/XML
>> editor.
>> Can you test again and report if this helped?
> I' ll try first with another very BIG project (mutltiple grass
> rasters-vectors, shapefiles, styling, etc.).
> Thanks, Nikos
> [1]
> Warning: QPainter::begin: Cannot paint on a null pixmap
> Warning: QPainter::end: Painter not active, aborted
> Warning: QPainter::setPen: Painter not active
> Warning: QPainter::setFont: Painter not active
> Warning: QPixmap::scaled: Pixmap is a null pixmap
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
