[Qgis-user] Missing qwt5 for qgis_unstable under Ubuntu Jaunty
    William Kyngesburye
    woklist at kyngchaos.com
    Tue Apr 28 05:21:02 PDT 2009
On Apr 28, 2009, at 5:23 AM, Nikos Alexandris wrote:
> Working with qgis_unstable, under Ubuntu Jaunty / 64-bit, I try to
> install several plugins that need the qwt5 python module (e.g. Value
> Tool and Profile). There is some conflict in the Ubuntu repositories
> which won't let for example "python-qwt5-qt4" install [1][2].
> So attempting to install these qgis-plugins returns:
> The plugin depends on some components missing on your system. You need
> to install the following Python module in order to enable it: Qwt5
> I decided to get the source "PyQwt-5.1.1 for Qt-4" and build/install
> it
> [3]. Unfortunately qgis doesn't see the installed qwt5 module. Any
> ideas
> on how to make it work?
What I found when trying to install it for OSX is that Qwt5 must be
inside the PyQt space (ie in the Pyqt folder), because it's loaded
with "from PyQt4.Qwt5 import *".
If you have multiple PyQt installations, make sure you're installing
Qwt in the same PyQt that Qgis is loading.
PS. are there a lot of Qgis plugins now that use Qwt5?  For OSX
packaging I may need to bundle Qwt5 in the Qgis app, at least for Qgis
1.1.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
