[Qgis-user] gdal tools plugin not working
Paolo Cavallini cavallini at faunalia.it
Thu Dec 31 02:51:03 PST 2009
Hubert Kivit ha scritto:
> I activated the Gdal tools plugin (0.0.18) in QGis 1.3.0 through the
> plugin-manager, and used the Tanslate-utility. When I hit OK I got the
> following error: "The process failed to start. Either the invoked
> program is missing, or you may have insufficient permissions to invoke
Are you on Windows? In this case, you probably do not have the path to gdal
executables in you system. Just adding them should do.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
