[Qgis-user] Confirmation of compiling of QGIS 1.0 on Mandriva 2009 x86_64
Mikhail Umorin
Mikhail.Umorin at twdb.state.tx.us
Tue Feb 3 13:01:31 PST 2009
I compiled 1.0.0-Kore (code revision 10094) with PostgreSQL, Python and
Grass support, against Qt 4.4.3 on Intel, on Mandriva 2009, x86_64.
Following compilation complaints/warnings:
[ 65%] Generating core/core.so
/usr/share/sip/PyQt4/QtCore/qmap.sip: In function ‘PyObject*
convertFrom_QMap_1800_0200QgsGeometry(void*, PyObject*)’:
/usr/share/sip/PyQt4/QtCore/qmap.sip:170: warning: suggest explicit
braces to avoid ambiguous ‘else’
convertFrom_QMap_1800_0200QgsField(void*, PyObject*)’:
[ 65%] Generating gui/gui.so
[ 66%] Built target python
[ 67%] Generating ui_qgshelpviewerbase.h
/var/Archives/qgis/qgis_1.0.0/src/helpviewer/qgshelpviewerbase.ui: An
invalid icon property 'windowIcon' was encountered.
[ 71%] Generating ui_pluginguibase.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/copyright_label/pluginguibase.ui:
An invalid icon property 'windowIcon' was encountered.
[ 71%] Generating moc_plugin.cxx
[ 73%] Generating ui_qgsdelimitedtextpluginguibase.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui:
[ 73%] Generating moc_qgsdelimitedtextplugin.cxx
[ 81%] Generating ui_pluginguibase.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/north_arrow/pluginguibase.ui:
[ 81%] Generating moc_plugin.cxx
[ 82%] Generating ui_pluginguibase.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/scale_bar/pluginguibase.ui:
[ 82%] Generating moc_plugin.cxx
[ 85%] Generating ui_qgsgpspluginguibase.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/gps_importer/qgsgpspluginguibase.ui:
Scanning dependencies of target gpsimporterplugin
[ 90%] Generating ui_pluginguibase.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/georeferencer/pluginguibase.ui:
[ 90%] Generating ui_qgspointdialogbase.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/georeferencer/qgspointdialogbase.ui:
An invalid icon property 'icon' was encountered.
[ 91%] Generating ui_mapcoordsdialogbase.h
[ 94%] Generating ui_coordinatecaptureguibase.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/coordinate_capture/coordinatecaptureguibase.ui:
[ 94%] Generating moc_coordinatecapture.cxx
[ 96%] Generating ui_dxf2shpconvertergui.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui:
[ 96%] Generating moc_dxf2shpconverter.cxx
[ 98%] Built target dxf2shpconverterplugin
[ 99%] Generating ui_ogrconverterguibase.h
/var/Archives/qgis/qgis_1.0.0/src/plugins/ogr_converter/ogrconverterguibase.ui:
[ 99%] Generating moc_plugin.cxx
The app looks great. Also, "Check Qgis version" does not seem to
produce any effect except a busy mouse cursor.
Just FYI
Mikhail.
