[Qgis-user] gps formats
Agustin Lobo
aloboaleu at gmail.com
Thu Feb 5 10:26:54 PST 2009
I'm trying to display a gps track file in IGC format
The GPS plugin gives an error at converting the IGC file
into GPX. Nevertheless, I can do it in the terminal with no problem,i.e.:
gpsbabel -i IGC -f test2009.IGC -o gpx -F test2009.gpx
works fine and I can display test2009.gpx with the GPS plugin.
If the GPS plugin is suppossed to use gpsbabel, why does it
not work with the IGC file?
Thanks
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
