[Qgis-user] Adding grid lines to a map
    John C. Tull
    john.tull at wildnevada.org
    Sat Feb  7 09:05:28 PST 2009
On Feb 7, 2009, at 8:38 AM, Matt Rosales wrote:
> Hi All,
> I am working on a map that I need to print for field reference, and
> I cannot see a good way of putting 10 metre gridlines over the map.
> Does anyone have any ideas?
> Cheers!
> Matt
Matt,
If you are using Qgis 1.0.0 or higher, you can use the fTools plugin
to do this. It is under the Sampling Tools subdirectory of the Tools
menu once it is installed and activated. Your challenge will be in
creating good labels for the lines.
Regards,
John
