[Qgis-user] Set item position in print-composer does not work (?)
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Mon Feb 9 05:09:15 PST 2009
Hi Nikos
Did you set the items x-/y- position before pressing the 'set item position'
button? Because the tool automatically inserts the current position of the
item (in mm). Therefore pressing the button without setting the position to a
different value does not change anything.
Regards,
Marco
Am Montag 09 Februar 2009 14:00:30 schrieb Nikos Alexandris:
> Hi all!
> The print-composer is getting more and more attractive. Does the "set
> item position" under the "Item" tab work?
> Thanks, Nikos
> Qgis-user mailing list
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
