[Qgis-user] Set item position in print-composer does not work (?)
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Mon Feb  9 05:54:03 PST 2009
On Mon, 2009-02-09 at 14:09 +0100, Marco Hugentobler wrote:
> Hi Nikos
> Did you set the items x-/y- position before pressing the 'set item
> position'
> button? Because the tool automatically inserts the current position of
> the
> item (in mm). Therefore pressing the button without setting the
> position to a
> different value does not change anything.
> Regards,
> Marco
Hi Marco!
[Working with QGIS 1.1.0-Unstable-trunk, code revision 10014)]
The x-/y- fields are already filled with values. However, I put values
manually again but it doesn't seem to work.
Regards, Nikos
