[Qgis-user] Set item position in print-composer does not work (?)
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Mon Feb 9 05:56:12 PST 2009
Hi Nikos
The fields show the current position.
You need to press 'set position' after changing the values. If that does not
work for you: on what platform are you using QGIS?
Regards,
Marco
Am Montag 09 Februar 2009 14:54:03 schrieb Nikos Alexandris:
> On Mon, 2009-02-09 at 14:09 +0100, Marco Hugentobler wrote:
> > Hi Nikos
> > Did you set the items x-/y- position before pressing the 'set item
> > position'
> > button? Because the tool automatically inserts the current position of
> > the
> > item (in mm). Therefore pressing the button without setting the
> > position to a
> > different value does not change anything.
> > Regards,
> > Marco
> Hi Marco!
> [Working with QGIS 1.1.0-Unstable-trunk, code revision 10014)]
> The x-/y- fields are already filled with values. However, I put values
> manually again but it doesn't seem to work.
> Regards, Nikos
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
