[Qgis-user] Set item position in print-composer does not work (?)
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Feb 9 06:25:38 PST 2009
Yep, it works! Although, I can't imagine that I did not press the "set
position" in my previous test.
1. Select item
2. Position # already filled with values (e.g. x: 3.63564, y: 237.727)
3. Select an Item-Point "box" with the mouse (e.g. center-center) #
values change automatically to x: 24.1356, y: 267.477
4. Select "Set position" # no re-action
5. Set manually some values (e.g. x:20, y:220) # now it works :-)
Thank you for your attention Marco.
Nikos
Working on Ubuntu II/64-bit
