[Qgis-user] Problem with HomeRange plugin - rgdal dependencies
    Anne Ghisla
    a.ghisla at gmail.com
    Wed Feb 11 01:41:13 PST 2009
Hello Sebastian, list members,
On Tuesday 10 February 2009 18:48:12 Paolo Cavallini wrote:
> Sebastian Cruz ha scritto:
> > Hello,
> > I am having problems installing the rgdal R package, I have installed it
> > via the package installer. But when I check the package manager it shows
> > as 'not loaded' and will not allow me to load it. Do I need to install
> > other packages for it to work?
> If you install it with dep=TRUE, it should install all the dependencies.
> Please keep on writing to the mailing list, ther will be more people
> able to reply.
Right. Dependencies problems are the most common using HomeRange plugin, as
the coupling with R is not so tight: the plugin is not supposed to install
missing packages.
As Paolo pointed out, it is better to install the required packages with the R
command (on Linux you need to be root)
install.packages("package_name", dep=TRUE)
It will assure the complete set of dependencies. Otherwise you can also check
the dependencies on each package's web page and download them manually - but
it is more complicated.
See also the wiki page [0] of the plugin for more information.
all the best,
Anne
[0] http://wiki.qgis.org/qgiswiki/GSoC2008Rbinding
Please consider the environment before printing this email
Please do not send attachments in proprietary formats
http://www.gnu.org/philosophy/no-word-attachments.html
Use the UNI CEI Standard ISO/IEC 26300:2006
O< stop html mail - http://www.asciiribbon.org
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090211/7ce4184e/attachment.sig>
