[Qgis-user] Problem with HomeRange plugin - rgdal dependencies
    John C. Tull
    john.tull at wildnevada.org
    Wed Feb 11 09:54:21 PST 2009
I'm also on OS X using qgis built from the current svn trunk. I would
run a quick test with a point file with 25 points and a single id
variable (one individual home range to compute). After taking care of
the rgdal dependency, I am now running into problems with the output
of the computed shapefile while running the plugin. Here is the error
I receive in a dialog window:
R error: Error in writeOGR(khr.polygons, dir, name, "ESRI Shapefile") :
GDAL Error 1: Failed to create file .shp file.
Any ideas on how to fix this?
Regards,
John
On Feb 11, 2009, at 1:41 AM, Anne Ghisla wrote:
> Hello Sebastian, list members,
> On Tuesday 10 February 2009 18:48:12 Paolo Cavallini wrote:
>> Sebastian Cruz ha scritto:
>>> Hello,
>>> I am having problems installing the rgdal R package, I have
>>> installed it
>>> via the package installer. But when I check the package manager it
>>> shows
>>> as 'not loaded' and will not allow me to load it. Do I need to
>>> install
>>> other packages for it to work?
>> If you install it with dep=TRUE, it should install all the
>> dependencies.
>> Please keep on writing to the mailing list, ther will be more people
>> able to reply.
> Right. Dependencies problems are the most common using HomeRange
> plugin, as
> the coupling with R is not so tight: the plugin is not supposed to
> install
> missing packages.
> As Paolo pointed out, it is better to install the required packages
> with the R
> command (on Linux you need to be root)
> install.packages("package_name", dep=TRUE)
> It will assure the complete set of dependencies. Otherwise you can
> also check
> the dependencies on each package's web page and download them
> manually - but
> it is more complicated.
> See also the wiki page [0] of the plugin for more information.
> all the best,
> Anne
> [0] http://wiki.qgis.org/qgiswiki/GSoC2008Rbinding
> Please consider the environment before printing this email
> Please do not send attachments in proprietary formats
> http://www.gnu.org/philosophy/no-word-attachments.html
> Use the UNI CEI Standard ISO/IEC 26300:2006
> O< stop html mail - http://www.asciiribbon.org
> Qgis-user mailing list
