AW: [Qgis-user] Two or more maps in the print composer
Borys Jurgiel
borysiasty at aster.pl
Tue Feb 17 01:20:48 PST 2009
Tuesday 17 February 2009 08:12:24 Hugentobler Marco napisał(a):
> Hi Nikos
> It is possible to print different extents of the same map. The possibility to
> have different layers loaded for the different map is planned for the next
> stage of composer development this year.
It's possible to print different layers even now but only if the maps are in
different scales (e.g. a main map + an overview). You can add all layers to the
map canvas and set the 'scale dependent rendering' to determine where to place
each of them.
Regards,
B.
> Regards,
> Marco
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Nikos Alexandris
> Gesendet: Di 17.02.2009 05:26
> An: qgis-user List
> Betreff: [Qgis-user] Two or more maps in the print composer
> Hi all!
> If I understand the concept, the print composer enables viewing of
> multiple maps and successively printing/saving.
> What I can't figure out is how to load "different" maps (raster or
> vector) on the different map frames I have currently on-display (in the
> print composer I mean). Is it working or is it still "on-the-way"?
> Thank you, Nikos
> Qgis-user mailing list
