[Qgis-user] delimited text
John C. Tull
john.tull at wildnevada.org
Tue Feb 17 19:00:17 PST 2009
Declan,
I've found that the plugin is very picky about line endings. You will
need to use a text editor that can change your line endings from Mac
to another format such as DOS or a unix format. Of course, it would be
nice for the plugin to not care. I always forget this, and spend a few
more minutes than I want recalling the reason and working it out.
Cheers,
John
On Feb 17, 2009, at 2:31 PM, Declan Troy wrote:
> Hi,
> I'm experimenting with the delimited text plugin. My text file has
> the fields delimited with tabs. The plugin seems to parse the field
> correctly, the sample text window shows the file correctly and the
> field names are listed in the X field and Y field boxes BUT the end
> of lines of data are not recognized (even though things look ok in
> the sample text). The entire file gets imported as a single record
> and the cell values are listed as options for the X and Y fields.
> One peculiar feature is the first field of the each record (this
> happens to be the X value, longitude) is concatenated with the last
> record of the preceding record, otherwise all cells are distinct but
> treated as one long record.
> Any clues as to what I'm doing wrong or a possible solution to get
> the end of lines recognized? Note these text files can be read
> without problem in R.
> I'm using qgis 1.0.0 on OS X
> Thanks,
> Declan
> Qgis-user mailing list
