[Qgis-user] import vector layer .shp in grass
    Paolo Cavallini
    cavallini at faunalia.it
    Fri Feb 20 08:15:47 PST 2009
snuffer892 ha scritto:
> vector layer (.shp) from qgis to grass. I use the plugin v.in.ogr, but it
> does not works if I want to import the attribute of the layer. It works if I
> don't import the attribute. Are there any setting I don't set fine?
Hi snuffer,
ahve you defined a database connection for GRASS? Evene a dbf is fine.
What does the process say? Any error/warning?
All the best.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
