[Qgis-user] import vector layer .shp in grass
snuffer892
paolo_tome at hotmail.com
Fri Feb 20 11:51:31 PST 2009
hello, thanks for the help. I have managed to solve my problem in this way:
- copying the attributes of the layer (.shp) in calc;
- saving in the .csv extension
- importing the attribute in a MySQL database
- connect the raster to the database
- import the coordinates by the plugin: v.in.db
(non riuscivo ad importare il layer .shp direttamente assieme ai relativi
attributi, in quanto quando lanciavo il plugin v.in.ogr l'operazione non
andava a buon fine poichè andava in crash...non mi dava errori particolari,
ma solamente una dicitura che mi diceva appunto che l'operazione era andata
in crash..hai qualche idea sul perchè? cosa potrei aver sbagliato? grazie
mille per la disponibilità )
Paolo Cavallini wrote:
> snuffer892 ha scritto:
>> vector layer (.shp) from qgis to grass. I use the plugin v.in.ogr, but it
>> does not works if I want to import the attribute of the layer. It works
>> if I
>> don't import the attribute. Are there any setting I don't set fine?
> Hi snuffer,
> ahve you defined a database connection for GRASS? Evene a dbf is fine.
> What does the process say? Any error/warning?
> All the best.
> pc
> Paolo Cavallini, see: * http://www.faunalia.it/pc *
> Qgis-user mailing list
View this message in context: http://n2.nabble.com/import-vector-layer-.shp-in-grass-tp2354810p2360983.html
Sent from the qgis-user mailing list archive at Nabble.com.
