[Qgis-user] AW: [Qgis-developer] New Plugin builder
Düster Horst
Horst.Duester at bd.so.ch
Sun Feb 22 23:59:24 PST 2009
Gary
Great work and very very helpful for plugin developement.
I found out one issue in conjunction with QT-Designer. When I open the
generated *.ui file with QT-Designer and save the file then the
UI-Classname is not set correct. P.e. when you call a class myTestClass
you will get a UI_myTestClass.ui with the corresponding class name. Open
the file with QT-Designer add a push button and save the dialog, the
dialog class is renamed in UI_Dialog but not the file of course. As the
result the plugin throws an error message "class not found". To solve
the problem you have to rename the dialog inside of QT-Designer from
Dialog to your desired class name.
Regards
Horst
Dr. Horst Düster
Stv. Amtschef / GIS-Koordinator
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: Gary Sherman [mailto:sherman at mrcc.com]
Gesendet am: Samstag, 21. Februar 2009 23:30
An: qgis-user; qgis-developer List
Betreff: [Qgis-developer] New Plugin builder
I have created a web-based tool to build a minimal QGIS Python plugin.
Basically you specify the required parameters and it creates a ready
to run plugin with an blank dialog. The tool compiles the resource and
Ui files and packages it all up into a zip file for download.
You can try the builder at: http://pyqgis.org/builder/plugin_builder.py
The zip file contains a Makefile which can be used to recompile the Ui
and resource files if you change them. The builder uses Qt 4.4,
however the generated plugin should work on any QGIS 1.0 install.
If you've been wanting to develop QGIS plugins but didn't know where
to start, this tool can get you started quickly by setting up the
structure for you.
Comments and suggestions are welcomed.
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
-Desktop GIS Book:
*http://desktopgisbook.com
"We work virtually everywhere"
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090223/b1430728/attachment.html>
