[Qgis-user] Re: AW: [Qgis-developer] New Plugin builder
    Gary Sherman
    sherman at mrcc.com
    Mon Feb 23 08:09:29 PST 2009
On Feb 22, 2009, at 10:59 PM, Düster Horst wrote:
> Gary
> Great work and very very helpful for plugin developement.
> I found out one issue in conjunction with QT-Designer. When I open
> the generated *.ui file with QT-Designer and save the file then the
> UI-Classname is not set correct. P.e. when you call a class
> myTestClass you will get a UI_myTestClass.ui with the corresponding
> class name. Open the file with QT-Designer add a push button and
> save the dialog, the dialog class is renamed in UI_Dialog but not
> the file of course. As the result the plugin throws an error message
> "class not found". To solve the problem you have to rename the
> dialog inside of QT-Designer from Dialog to your desired class name.
An oversite in the template that generates the Ui file. It should be
fixed now.
Thanks,
-gary
> Regards
> Horst
> Dr. Horst Düster
> Stv. Amtschef / GIS-Koordinator
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> -----Ursprüngliche Nachricht-----
> Von: Gary Sherman [mailto:sherman at mrcc.com]
> Gesendet am: Samstag, 21. Februar 2009 23:30
> An: qgis-user; qgis-developer List
> Betreff: [Qgis-developer] New Plugin builder
> I have created a web-based tool to build a minimal QGIS Python plugin.
> Basically you specify the required parameters and it creates a ready
> to run plugin with an blank dialog. The tool compiles the resource and
> Ui files and packages it all up into a zip file for download.
> You can try the builder at: http://pyqgis.org/builder/
> plugin_builder.py
> The zip file contains a Makefile which can be used to recompile the Ui
> and resource files if you change them. The builder uses Qt 4.4,
> however the generated plugin should work on any QGIS 1.0 install.
> If you've been wanting to develop QGIS plugins but didn't know where
> to start, this tool can get you started quickly by setting up the
> structure for you.
> Comments and suggestions are welcomed.
> -gary
> -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> Gary Sherman
> Chair, QGIS Project Steering Committee
> -Micro Resources: http://mrcc.com
> *Geospatial Hosting
> *Web Site Hosting
> -Desktop GIS Book:
> *http://desktopgisbook.com
> "We work virtually everywhere"
> Qgis-developer mailing list
Gary Sherman
   *Geospatial Hosting
   *Web Site Hosting
-Desktop GIS Book:
