[Qgis-user] Re: [Qgis-developer] Properties dialog too big for small displays (eee PC display)
Agustin Lobo
aloboaleu at gmail.com
Sat Feb 28 01:52:33 PST 2009
Otto,
the problem is not moving the properties dialog, the problem is that
it's too large and even moving it to the top I cannot reach the buttons
at the bottom.
Agus
Message: 2 Date: Fri, 27 Feb 2009 08:53:08 +0100
Subject: [Qgis-user] Re: [Qgis-developer] Properties dialog too big for
To: qgis-user <qgis-user at lists.osgeo.org> Cc: qgis-developer
<qgis-developer at lists.osgeo.org> Message-ID:
<20090227085308.55a62d04 at nature> Content-Type: text/plain;
charset=US-ASCII On Fri, 27 Feb 2009 08:44:59 +0100 Agustin Lobo
<Agustin.Lobo at ija.csic.es> wrote:
> > I'm running QGIS on a ASUS eee PC 901 under
> > ubuntu eee 8.04. I find no major
> > problems except that the GUI panel
> > for Properties is so big that I cannot
> > reach the buttons at the bottom and
> > cannot select OK, thus no way of
> > using it. I cannot resize the window to
> > make it smaller. The display is 1024x600
> > Any solution?
pressing keys (Alt + 5) together you should be able to click on the
properties
dialog with the left mouse button and move it upwards (or whereever).
hth
Otto
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
