[Qgis-user] Re: [Qgis-developer] Properties dialog too big for small displays (eee PC display)
Matt Rosales
m.rosales.geo at gmail.com
Sat Feb 28 10:38:13 PST 2009
If you are using Compiz desktop effects, one of the plugins (in a terminal:
sudo apt-get install compiz-config-manager if I remember correctly) lets you
resize and move windows by holding cntrl+first mouse button and alt+first
mouse button respectively. Maybe that will help? Also look in the "keyboard
shortcuts" menu under System>Preferences, I think there is a shortcut to
resize windows that way.
Does that help?
Matt
On Sat, Feb 28, 2009 at 9:52 AM, Agustin Lobo <aloboaleu at gmail.com> wrote:
> Otto,
> the problem is not moving the properties dialog, the problem is that it's
> too large and even moving it to the top I cannot reach the buttons
> at the bottom.
> Agus
> Message: 2 Date: Fri, 27 Feb 2009 08:53:08 +0100
> From: Otto Dassau <otto.dassau at gmx.de>
> Subject: [Qgis-user] Re: [Qgis-developer] Properties dialog too big for
> To: qgis-user <qgis-user at lists.osgeo.org> Cc: qgis-developer <
> qgis-developer at lists.osgeo.org> Message-ID:
> <20090227085308.55a62d04 at nature> Content-Type: text/plain;
> charset=US-ASCII On Fri, 27 Feb 2009 08:44:59 +0100 Agustin Lobo
> <Agustin.Lobo at ija.csic.es> wrote:
> > > I'm running QGIS on a ASUS eee PC 901 under
> > > ubuntu eee 8.04. I find no major
> > > problems except that the GUI panel
> > > for Properties is so big that I cannot
> > > reach the buttons at the bottom and
> > > cannot select OK, thus no way of
> > > using it. I cannot resize the window to
> > > make it smaller. The display is 1024x600
> > > Any solution?
> pressing keys (Alt + 5) together you should be able to click on the
> properties
> dialog with the left mouse button and move it upwards (or whereever).
> hth
> Otto
> Dr. Agustin Lobo
> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
> LLuis Sole Sabaris s/n
> 08028 Barcelona
> Spain
> Tel. 34 934095410
> Fax. 34 934110012
> email: Agustin.Lobo at ija.csic.es
> http://www.ija.csic.es/gt/obster
> Qgis-user mailing list
matt at mattrosales.com
GPG Key ID: 113828CC
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090228/bc7eac24/attachment.html>
