[Qgis-user] dependencies on OpenSuSE 11.1 KDE4
Otto Dassau otto.dassau at gmx.de
Thu Jan 1 10:17:28 PST 2009
Hi Gian,
packages for OpenSUSE 11.1 and factory are available now and I hope your libgeos
proplem is fixed. Please report if sth. doesn't work as expected.
 Otto
On Tue, 30 Dec 2008 19:21:02 -0300
"G. Paolo Sanino V." <research at leviathanchile.org> wrote:
> Dear Brent and Otto,
> Thanks you so much for your reply. It happened so fast, making such a
> difference with other mailing list supports. No surprise why QGIS is so great.
> I use it all the time in my job.
> The repositories that you sent me are in fact the ones I have been looking on.
> QGIS is not there yet, but I found it at:
> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_Factory/
> However, dependencies fail missing only: libgeos-3.0.0.so()(64bit).
> Then I will wait for it. Congratulations for this great application
> Thanks a gain, and have a happy new year!
> Gian
> On Tue 30 Dec 2008 06:37:59 Otto Dassau wrote:
> > Dear Gian,
> > On Mon, 29 Dec 2008 20:36:39 -0300
> > > Hi,
> > > I just moved to the new openSUSE 11.1 (x86_64) with KDE 4.1.3.
> > > Not that happy with the changes but too late to walk back...
> > > Under OS11.0 is was as simple as use Yast, search for Qgis and thet
> > > getting installed. However, in 11.1 qgis does not shows up on the
> > > defaults list of application packages. Then after adding several
> > > repositories it shows up at "factory". As well as from www.opensuse.org,
> > > the one clik utility worked fine in finding qgis under OpenSuSE-Factory.
> > > However, using the online tool or Yast
> > > with the repositories, I cannot get QGIS installed due to the missing:
> > > Looking at RPM find and other sites, I found two packages that contain
> > > this library but no way to install any of them, as they present even more
> > > failed dependencies during the attempts.
> > > Is this happening to somebody else? if so, have you found a workaround to
> > > get qgis installed in this distro?
> > > Thanks a lot! and congratulations for the great work on QGIS.
> > I just started to create QGIS 1.0.0 packages for OpenSUSE at the OpenSUSE
> > Application:Geo server. Don't know if that is where you have been looking
> > for QGIS?
> > Most versions are done, but there are some dependencies failing for 11.1
> > and factory yet. I will have a look to fix this soon, before we have the
> > official QGIS release.
> > regards,
> >  Otto
> > > Gian
