[Qgis-user] dependencies on OpenSuSE 11.1 KDE4
    G. Paolo Sanino V.
    research at leviathanchile.org
    Thu Jan  1 14:24:40 PST 2009
Hi Otto,
I just installed QGIS in OpenSuSE11.1 (KDE4.1.3) and it works perfectly.
Again, thank you so much and receive my best wished for this new year.
with warmest regards,
Gian
On Thu 01 Jan 2009 15:17:28 Otto Dassau wrote:
> Hi Gian,
> packages for OpenSUSE 11.1 and factory are available now and I hope your
> libgeos proplem is fixed. Please report if sth. doesn't work as expected.
>  Otto
> On Tue, 30 Dec 2008 19:21:02 -0300
> "G. Paolo Sanino V." <research at leviathanchile.org> wrote:
> > Dear Brent and Otto,
> > Thanks you so much for your reply. It happened so fast, making such a
> > difference with other mailing list supports. No surprise why QGIS is so
> > great. I use it all the time in my job.
> > The repositories that you sent me are in fact the ones I have been
> > looking on.
> > QGIS is not there yet, but I found it at:
> > http://download.opensuse.org/repositories/Application:/Geo/openSUSE_Facto
> >ry/
> > However, dependencies fail missing only: libgeos-3.0.0.so()(64bit).
> > Then I will wait for it. Congratulations for this great application
> > Thanks a gain, and have a happy new year!
> > Gian
> > On Tue 30 Dec 2008 06:37:59 Otto Dassau wrote:
> > > Dear Gian,
> > > On Mon, 29 Dec 2008 20:36:39 -0300
> > > > Hi,
> > > > I just moved to the new openSUSE 11.1 (x86_64) with KDE 4.1.3.
> > > > Not that happy with the changes but too late to walk back...
> > > > Under OS11.0 is was as simple as use Yast, search for Qgis and thet
> > > > getting installed. However, in 11.1 qgis does not shows up on the
> > > > defaults list of application packages. Then after adding several
> > > > repositories it shows up at "factory". As well as from
> > > > www.opensuse.org, the one clik utility worked fine in finding qgis
> > > > under OpenSuSE-Factory. However, using the online tool or Yast
> > > > with the repositories, I cannot get QGIS installed due to the
> > > > missing:
> > > > Looking at RPM find and other sites, I found two packages that
> > > > contain this library but no way to install any of them, as they
> > > > present even more failed dependencies during the attempts.
> > > > Is this happening to somebody else? if so, have you found a
> > > > workaround to get qgis installed in this distro?
> > > > Thanks a lot! and congratulations for the great work on QGIS.
> > > I just started to create QGIS 1.0.0 packages for OpenSUSE at the
> > > OpenSUSE Application:Geo server. Don't know if that is where you have
> > > been looking for QGIS?
> > > Most versions are done, but there are some dependencies failing for
> > > 11.1 and factory yet. I will have a look to fix this soon, before we
> > > have the official QGIS release.
> > > regards,
> > >  Otto
> > > > Gian
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090101/687230b5/attachment.html>
