[Qgis-user] QGIS 1.0.0 incompatybile library version module
    Tim Sutton
    tim at linfiniti.com
    Thu Jan  1 14:08:09 PST 2009
Hi
Can you check if any old versions of QGIS exist on your system and
remove them if present - QGIS 1.x does not work well with older QGIS
libs present on your system. I'm not sure if that is indeed what is
causing your problem, but its the first place you should look...
Regards
Tim
On Wed, 2008-12-31 at 16:31 +0100, Jarek Jasiewicz wrote:
> Hi
> This message appears during starting qgis (Latest complilation from svn
> head),
> probably during  loading plugin-is, in message window titled in polish:
> "Nieobsługiwany błąd krytyczny":
> this polish message can be translated as "not supported critical error",
> I cannot say what is its source
> next program stop to work. Removing qgis both from /usr/local and
> ~/.qgis directories and successive compilation and do not solve the problem
> ldd /usr/local/binqgis load all libraries withouth error
> I cannot say nothing more about possible reason of that error. I use
> Ubuntu 8.04 with laetest version of Qt and grass 6.4 also just complied
> from svn head
> Jarek
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090102/2e481554/attachment.sig>
