[Qgis-user] QGIS 1.0.0 incompatybile library version module
Jarek Jasiewicz jarekj at amu.edu.pl
Fri Jan 2 02:17:22 PST 2009
There are no old qgis, I only use svn head, but I found reason: old
GRASS version (6.2.2) from ubuntu repositories. I remove that version
and compiled qgis again. All works fine. It was probably conflict with
libgrass libaries
Thanks for ansver
Jarek
Tim Sutton pisze:
> Hi
> Can you check if any old versions of QGIS exist on your system and
> remove them if present - QGIS 1.x does not work well with older QGIS
> libs present on your system. I'm not sure if that is indeed what is
> causing your problem, but its the first place you should look...
> Regards
> Tim
> On Wed, 2008-12-31 at 16:31 +0100, Jarek Jasiewicz wrote:
>> Hi
>> This message appears during starting qgis (Latest complilation from svn
>> head),
>> probably during  loading plugin-is, in message window titled in polish:
>> "Nieobsługiwany błąd krytyczny":
>> this polish message can be translated as "not supported critical error",
>> I cannot say what is its source
>> next program stop to work. Removing qgis both from /usr/local and
>> ~/.qgis directories and successive compilation and do not solve the problem
>> ldd /usr/local/binqgis load all libraries withouth error
>> I cannot say nothing more about possible reason of that error. I use
>> Ubuntu 8.04 with laetest version of Qt and grass 6.4 also just complied
>> from svn head
>> Jarek
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
