[Qgis-user] Projection
Otto Dassau
otto.dassau at gmx.de
Wed Jan 7 00:05:46 PST 2009
Hi Werner,
I tried to find your raster file projection "UTM_WGS84_M15", but it doesn't seem
to be available. What happens if you create your own CRS in QGIS. From your .prj
file this should work:
Setings -> Custom CRS
Parameters: +proj=tmerc +lat_0=0 +lon_0=15 +k=0.9996 +x_0=500000 +y_0=-5000000
+ellps=WGS84 +units=m +datum=WGS84 +no_defs
Then you load the raster, which is projected in "UTM_WGS84_M15", choose your
custom projection in the Project Properties dialog, select "Enable OTF" and
load the shape. The vector should now fit with the raster.
regards,
Otto
On Mon, 05 Jan 2009 09:30:20 +0100
Werner Macho <werner.macho at gmail.com> wrote:
> Hi List!
> I gotta small problem here to proof that qgis is prime-time ready but ..
> i have a raster and 3 vektor layers that i want to overlay
> Rasterlayer is a geoTIF and as of .prj file:
PROJCS["UTM_WGS84_M15",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1
984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519
943295]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000],PA
RAMETER["False_Northing",-5000000],PARAMETER["Central_Meridian",15],PARAMETER["
Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0],UNIT["Meter",1]]
> therefore a UTM_WGS84_M15 which seems to be not in the list of
> projections (or am i wrong?)
> the Vektorlayers are normal shape files and as of .prj file:
PROJCS["MGI_Austria_GK_M34",GEOGCS["GCS_MGI",DATUM["D_MGI",SPHEROID["Bessel_184
1",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925
199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",750000.0],
PARAMETER["False_Northing",-5000000.0],PARAMETER["Central_Meridian",16.33333333
333334],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT[
"Meter",1.0]]
> which i expect to be the MGI / Austria M34 projection and i can find it
> in the KBS List
> So can anybody give me a hint howto solve the rasterlayer projection
> because otherwise i cant overlay vector OTF on the Raster (My
> Information is that it can only work in that direction.
> Thanks a lot
> regards
> Werner
> Qgis-user mailing list
