[Qgis-user] Projection
Werner Macho
werner.macho at gmail.com
Mon Jan 5 00:30:20 PST 2009
Hi List!
I gotta small problem here to proof that qgis is prime-time ready but ..
i have a raster and 3 vektor layers that i want to overlay
Rasterlayer is a geoTIF and as of .prj file:
PROJCS["UTM_WGS84_M15",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000],PARAMETER["False_Northing",-5000000],PARAMETER["Central_Meridian",15],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0],UNIT["Meter",1]]
therefore a UTM_WGS84_M15 which seems to be not in the list of
projections (or am i wrong?)
the Vektorlayers are normal shape files and as of .prj file:
PROJCS["MGI_Austria_GK_M34",GEOGCS["GCS_MGI",DATUM["D_MGI",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",750000.0],PARAMETER["False_Northing",-5000000.0],PARAMETER["Central_Meridian",16.33333333333334],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
which i expect to be the MGI / Austria M34 projection and i can find it
in the KBS List
So can anybody give me a hint howto solve the rasterlayer projection
because otherwise i cant overlay vector OTF on the Raster (My
Information is that it can only work in that direction.
Thanks a lot
regards
Werner
