[Qgis-user] [Fwd: Installing qgis 1.0.0 final under windows]
    Micha Silver
    micha at arava.co.il
    Thu Jan 15 00:23:45 PST 2009
Agustin Lobo wrote:
> I've sent these directions for my students
> to install qgis 1.00final + the required plugins under win
> for an exercise. Thought could be of some help
> for other people too.
> Comments and corrections appreciated!
> Many thanks to Marco Pasetti for the win binaries,
> and to all developers, releasers, community team etc
> Agus
> PS Why is QGIS not listed under Express Install?
> -------- Mensaje original --------
> Asunto: Installing qgis 1.0.0 final under windows
> Fecha: Tue, 13 Jan 2009 16:38:40 +0100
> De: Agustin Lobo <Agustin.Lobo at ija.csic.es>
> 0. Go to http://download.qgis.org/downloads.rhtml
> and from there to http://trac.osgeo.org/osgeo4w/
> and download the OSGeo4W Installer
> (http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe)
> 1. Uninstall previous version and be sure you delete your .qgis
> directory somewhere under your
> Documents and Settings directory
> 2. Start the Installer osgeo4w-setup.exe
> 3. You have to select Advanced Install (qgis is not listed under Express
>  Install)
> 4. Leave all options as by default and click Next until you reach
> a menu named Select Packages (You'll wait few seconds on menu
> named Progress, be patient).
> Note that, by default, you skip everything in that list, so if
> you do not select as I say in the next step you will install almost
> nothing.
> 5. Select qgis under Desktop and python-qgis under Libs
> (and do me a favour: if you see anything else mentioning qgis, please
> notify me)
> 6. Start QGIS and click on Plugins/Manage plugins
> 7. Select all plugins. Make sure you get "Plugin Installer (version
> 0.9.8)" selected.
> Review the list and check for any message of incompatibility: if you
> have any, this means that you did not delete your .qgis directory as I
> told you. In that case, exit qgis and delete
> the contents of the directory plugins under .qgis/python
> 8. Close the Manage Plugins tool by clicking OK. Now you should have
> "Fetch Python Plugins" under Plugins. Select this option.
> 9. Go to Repositories and then Add 3rd Party Repositories,
> then click tab Plugins and select "fTools for QGIS 1.0"
> and "Point Sampling Tool". You must enable the last one with
> the Plugin Manager and, as the message tells you, you must exit QGIS and
> restart it. A tab named Tools should be there. Point Sampling Tool is
> under Plugins/Analysis
> Hope I'm not missing anything!
Hi Agus:
Would you be interested to add "How to add support for *.ecw and *.sid
rasters" ??
i.e.:
5(a) . Following the instructions here:
http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal-ecw
download (requires registration and agreeing to the license) and install
the ERMapper SDK, and copy four *.dll files from the SDK to
C:\Windows\System32.
In the OSGeo installer, under Libs, select also gdal-ecw and gdal-mrsid.
Cheers,
Micha
> Agus
