[Qgis-user] Graticules
Agustin Lobo
Agustin.Lobo at ija.csic.es
Mon Jan 26 23:56:24 PST 2009
Carson,
This is actually almost perfect and I do confirm that works
in the projection being defined for the project.
The only improvement would be that once you select "Input Boundary
Layer" you should get the actual values written in the X,Y fields
of "Input Coordinates". In this way, the user could then select "Input
coordinates" to slightly modify the values (you normally want
the grid at rounded positions).
Thanks a lot
Agus
Carson Farmer wrote:
> Hi Augus
>> Agustin Lobo wrote:
>>>> Could be considered that the graticule creator work in projected
>>>> coordinates? It's hard making a UTM graticule by entering geographic
>>>> values. Also, it would useful if the default values for the extent
>>>> could be those of the displayed region and/or those of the extent of
>>>> a given layer.
> You could probably do this with the vector grid function in fTools as
> well...
> Though now that I think of it... you might be limited to geographic
> coordinates here as well... but you could probably get around this by
> specifying UTM coordinates, and defining the projection to be UTM after
> the grid is created... I'm not sure though...
> C
>> Tim Sutton wrote:
>>> On my last round of edits to the graticule plugin, I put in
>>> the groundwork for this. I will add it to the feature plan for 1.1
>> Hi,
>> if you use the GRASS plugin you can theoretically do such things with the
>> v.mkgrid module.
>> perhaps src/plugins/grass/modules/v.mkgrid.region.qgm needs to be updated
>> to give access to more module options:
>> http://grass.osgeo.org/grass64/manuals/html64_user/v.mkgrid.html
>> maybe as a new v.mkgrid.coor.qgm ?
>> Hamish
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
