[Qgis-user] problem upgrading to v 1.0.0 from Preview 2 - Ubuntu 7.10
Gavin Fleming
GavinF at mintek.co.za
Wed Jan 28 06:09:11 PST 2009
Yip, I had removed all plugins already, so that's not the problem.
Gavin
-----Original Message-----
From: Carson Farmer [mailto:carson.farmer at gmail.com]
Sent: 28 January 2009 14:06 PM
To: Gavin Fleming
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] problem upgrading to v 1.0.0 from Preview 2 -
Ubuntu 7.10
Hi Gavin,
> On Ubuntu 7.10
> I've done apt-get remove qgis and apt-get purge qgis as well as
> updated my apt-get sources and done apt-get update.
> The new QGIS 1.0.0 splash screen comes up, QGIS opens, but the top bar
> and 'about' still say Preview II and 'test qgis version' doesn't work.
> I click on 'Manage plugins' and get this:
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "", line 1, in
> AttributeError: 'module' object has no attribute 'qgisMinimumVersion'
This first problem is probably due to the fact that you have older
versions of plugin (namely fTools in this case) that are based on older
versions of QGIS. Your best bet is to remove (or simply move somewhere
else) these older plugins and update to the newer ones once QGIS is
properly installed...
This message is intended for the addressee only.
Information and attachments in this e-mail may contain confidential, proprietary, or legally privileged information.
If you are not the intended recipient, or responsible for delivery of the message to the intended recipient,
any disclosure, copying, distribution, or any action taken is prohibited and may be unlawful,
and could result in a claim against you.
