[Qgis-user] problem upgrading to v 1.0.0 from Preview 2 - Ubuntu	7.10
    Carson Farmer
    carson.farmer at gmail.com
    Wed Jan 28 04:06:06 PST 2009
Hi Gavin,
> On Ubuntu 7.10
> I've done apt-get remove qgis and apt-get purge qgis as well as
> updated my apt-get sources and done apt-get update.
> The new QGIS 1.0.0 splash screen comes up, QGIS opens, but the top bar
> and ‘about’ still say Preview II and ‘test qgis version’ doesn’t work.
> I click on 'Manage plugins' and get this:
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "", line 1, in
> AttributeError: 'module' object has no attribute 'qgisMinimumVersion'
This first problem is probably due to the fact that you have older
versions of plugin (namely fTools in this case) that are based on older
versions of QGIS. Your best bet is to remove (or simply move somewhere
else) these older plugins and update to the newer ones once QGIS is
properly installed...
