[Qgis-user] Export WMS Layer
Till Adams
adams at terrestris.de
Tue Jul 7 05:36:30 PDT 2009
Rainer,
it is not difficult to build the getmap request on your own. Take this
as an example and apply this to your WMS:
You can pick the Bbox coordinates from your QGIS window, then put the
request in a browser to check:
This is an example:
http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-5.625,45,0,50.625&WIDTH=256&HEIGHT=256
So change the URL[http://labs.metacarta.com/wms/vmap0] (that what you
put in QGIS), then the
layers [*basic*]
srid [4326]
bbox [-5.625,45,0,50.625]
Parameters to your WMS, and probably the width & height to get a bigger
image -
that's it,
Regards, Till
> Hi
> I am using a WMS layer, and would like to export the layer, as I see
> it after zooming, from QGIS to a picture format.
> Is there a way of either exporting from QGIS, or obtaining the URL
> request, so that I can use wget to download it externally?
> Thanks,
> Rainer
> P.S: I am using Linux (Ubuntu Hardy)
> Rainer M. Krug, Centre of Excellence for Invasion Biology,
> Stellenbosch University, South Africa
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
