[Qgis-user] Export WMS Layer
Rainer M Krug
r.m.krug at gmail.com
Tue Jul 7 05:39:25 PDT 2009
On Tue, Jul 7, 2009 at 2:36 PM, Till Adams<adams at terrestris.de> wrote:
> Rainer,
Thanks Till for the explanation below.
I think it would be a good idea to add away of retrievin g the URL
directly from the WMS layer in QGIS - that would make the whole
process a little bit easier.
Cheers
Rainer
> it is not difficult to build the getmap request on your own. Take this as an
> example and apply this to your WMS:
> You can pick the Bbox coordinates from your QGIS window, then put the
> request in a browser to check:
> This is an example:
> http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-5.625,45,0,50.625&WIDTH=256&HEIGHT=256
> So change the URL[http://labs.metacarta.com/wms/vmap0] (that what you put
> in QGIS), then the
> layers [*basic*]
> srid [4326]
> bbox [-5.625,45,0,50.625]
> Parameters to your WMS, and probably the width & height to get a bigger
> image -
> that's it,
> Regards, Till
>> Hi
>> I am using a WMS layer, and would like to export the layer, as I see
>> it after zooming, from QGIS to a picture format.
>> Is there a way of either exporting from QGIS, or obtaining the URL
>> request, so that I can use wget to download it externally?
>> Thanks,
>> Rainer
>> P.S: I am using Linux (Ubuntu Hardy)
>> Rainer M. Krug, Centre of Excellence for Invasion Biology,
>> Stellenbosch University, South Africa
> terrestris GmbH & Co. KG
> Irmintrudisstrasse 17
> 53111 Bonn
> Germany
> Till Adams
> Geschäftsführung
> Tel: +49 (0)228 / 962 899-52
> Fax: +49 (0)228 / 962 899-57
> adams at terrestris.de http://www.terrestris.de
> Amtsgericht Bonn, HRA 6835
> Komplementärin:
> terrestris Verwaltungs GmbH
> vertreten durch:
> Hinrich Paulsen, Till Adams
