[Qgis-user] Export WMS Layer
Till Adams
adams at terrestris.de
Tue Jul 7 05:44:33 PDT 2009
Rainer,
could be true, perhaps there is already s.th. for that.
I didn't use QGIS for longer time, but I know a bit about WMS...
Regards, Till
> On Tue, Jul 7, 2009 at 2:36 PM, Till Adams<adams at terrestris.de> wrote:
>> Rainer,
> Thanks Till for the explanation below.
> I think it would be a good idea to add away of retrievin g the URL
> directly from the WMS layer in QGIS - that would make the whole
> process a little bit easier.
> Cheers
> Rainer
>> it is not difficult to build the getmap request on your own. Take this as an
>> example and apply this to your WMS:
>> You can pick the Bbox coordinates from your QGIS window, then put the
>> request in a browser to check:
>> This is an example:
>> http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-5.625,45,0,50.625&WIDTH=256&HEIGHT=256
>> So change the URL[http://labs.metacarta.com/wms/vmap0] (that what you put
>> in QGIS), then the
>> layers [*basic*]
>> srid [4326]
>> bbox [-5.625,45,0,50.625]
>> Parameters to your WMS, and probably the width & height to get a bigger
>> image -
>> that's it,
>> Regards, Till
>>> Hi
>>> I am using a WMS layer, and would like to export the layer, as I see
>>> it after zooming, from QGIS to a picture format.
>>> Is there a way of either exporting from QGIS, or obtaining the URL
>>> request, so that I can use wget to download it externally?
>>> Thanks,
>>> Rainer
>>> P.S: I am using Linux (Ubuntu Hardy)
>>> Rainer M. Krug, Centre of Excellence for Invasion Biology,
>>> Stellenbosch University, South Africa
>> terrestris GmbH & Co. KG
>> Irmintrudisstrasse 17
>> 53111 Bonn
>> Germany
>> Till Adams
>> Geschäftsführung
>> Tel: +49 (0)228 / 962 899-52
>> Fax: +49 (0)228 / 962 899-57
>> adams at terrestris.de http://www.terrestris.de
>> Amtsgericht Bonn, HRA 6835
>> Komplementärin:
>> terrestris Verwaltungs GmbH
>> vertreten durch:
>> Hinrich Paulsen, Till Adams
53111 Bonn
Germany
Till Adams
Geschäftsführung
Komplementärin:
vertreten durch:
