[Qgis-user] PostGIS manager v0.5
Martin Dobias
wonder.sk at gmail.com
Fri Jul 10 04:45:37 PDT 2009
On Thu, Jul 9, 2009 at 8:02 AM, Micha Silver<micha at arava.co.il> wrote:
> Hello Martin:
> A few more points you might take into consideration:
> 1- The "VACUUM ANALYZE" warning appears also for views. That's probably
> unnecessary.
That's right...
> 2- To get the plugin working on windows, the psycopg2 library must be
> installed. That's available when using the OSGeo4W installer, thru the
> "Advanced" option. It's worth mentioning this (somewhere...).
It could be added somewhere to the description. Hopefully at some
point in future there will be improved metadata for plugins that will
state also the dependencies.
> 3- Is it possible to maintain the state of the Table of Contents list of
> schemas and tables from session to session? It's a minor point, but with a
> long list of tables, this might add a bit to usability.
That's an interesting idea, but how to keep the database view up-to-date?
Martin
