[Qgis-user] Editing buttons grayed out
Dejan.Gambin at pula.hr Dejan.Gambin at pula.hr
Tue Jul 14 05:33:08 PDT 2009
Thanks but,
You know what - I uninstalled the standalone version and installed the
Windows-OSGEO version. Everything works fine with this!! So there must be
some problem with standalone version...
regards, dejan
Werner Macho <werner.macho at gmail.com> wrote on 14.07.2009 14:16:42:
> hi!
> Well - as I know it works it must really be some trivial mistake..
> probably you expect the wrong buttons to work?
> I assume you already know that you cant have point AND lines AND
> polygons on ONE layer?
> Probably you edit a polygon layer and expect to draw points on it?
> even vertices are not available on point layers ..
> I just want to remind that ..
> Probably you expect the wrong things to happen ..
> regards
> Werner
> > Hi,
> > I am a QGIS beginner. I have installed the latest stable version 1.0.2
on my
> > Windows XP SP3 machine. I have created a new project and added a new
vector
> > layer (point). I have also added an existing vector layer (line).
> > I turned on "Toggle editing" on each of them but all the editing
buttons
> > (Capture point/line/polygon, Move feature, Move vertex, etc.) are
grayed
> > out.
> > Since I am a beginner I must be doing a trivial error but I don't know
which
> > Any help would be greatly appreciated
> > thanks very much
> > regards, dejan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090714/9e865565/attachment.html>
