[Qgis-user] Editing buttons grayed out
    Werner Macho
    werner.macho at gmail.com
    Tue Jul 14 05:16:42 PDT 2009
hi!
Well - as I know it works it must really be some trivial mistake..
probably you expect the wrong buttons to work?
I assume you already know that you cant have point AND lines AND
polygons on ONE layer?
Probably you edit a polygon layer and expect to draw points on it?
even vertices are not available on point layers ..
I just want to remind that ..
Probably you expect the wrong things to happen ..
regards
Werner
> Hi,
> I am a QGIS beginner. I have installed the latest stable version 1.0.2 on my
> Windows XP SP3 machine. I have created a new project and added a new vector
> layer (point). I have also added an existing vector layer (line).
> I turned on "Toggle editing" on each of them but all the editing buttons
> (Capture point/line/polygon, Move feature, Move vertex, etc.) are grayed
> out.
> Since I am a beginner I must be doing a trivial error but I don't know which
> Any help would be greatly appreciated
> thanks very much
> regards, dejan
