[Qgis-user] Fwd: Hello,
Sebastian Cruz
cruz.seb at gmail.com
Wed Jul 15 21:20:37 PDT 2009
Begin forwarded message:
> From: "John C. Tull" <john.tull at wildnevada.org>
> Date: 15 July 2009 22:10:47 GMT-06:00
> To: Sebastian Cruz <cruz.seb at gmail.com>
> Subject: Re: Hello,
> Sebastian,
> I'm really not much better (any?) at figuring this stuff out than
> you. I don't know why python would not be detected. Can you run
> python from the terminal? If so, try a command like 'import rpy2'
> and see what happens. Same with other modules you need.
> Frankly, the homerange plugin never quite worked for me on OS X. I
> think it did for a while, then did not. I'm not sure why, and I gave
> up. You may also look at the manageR plugin, but you will have to
> learn R commands for doing your analyses. R is a great program, and
> you can get the binary online. In fact, you should already have it
> to get rpy2 working (I think). Don't forget, rgdal is available from
> William's site as a binary. I assume you tried that.
> I would encourage you to contact the dev of the plugin if none of
> the above helps. They are better at reading those outputs than I am.
> Best,
> John
> On Jul 15, 2009, at 8:19 PM, Sebastian Cruz wrote:
>> Hi John,
>> I have to say I am not surprised by your reaction to the email I
>> sent you, I also cannot make any sense out of it (and I know very
>> little compared to you). I was wondering if the following messages
>> makes more sense to you:
>> Couldn't load plugin "HomeRange_plugin" from ['/Applications/
>> Qgis.app/Contents/MacOS/share/qgis/python', '/Users/
>> sebastiancruz/.qgis//python/plugins', '/Applications/Qgis.app/
>> Contents/MacOS/share/qgis/python/plugins', '/Library/Frameworks/
>> GDAL.framework/Versions/1.6/Python/site-packages', '/Library/Python/
>> 2.5/site-packages/SQLObject-0.10.6-py2.5.egg', '/System/Library/
>> Frameworks/Python.framework/Versions/2.5/lib/python25.zip', '/
>> System/Library/Frameworks/Python.framework/Versions/2.5/lib/
>> python2.5', '/System/Library/Frameworks/Python.framework/Versions/
>> 2.5/lib/python2.5/plat-darwin', '/System/Library/Frameworks/
>> Python.framework/Versions/2.5/lib/python2.5/plat-mac', '/System/
>> Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-
>> mac/lib-scriptpackages', '/System/Library/Frameworks/
>> Python.framework/Versions/2.5/Extras/lib/python', '/System/Library/
>> Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk', '/
>> python2.5/lib-dynload', '/Library/Python/2.5/site-packages', '/
>> System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/
>> python/PyObjC', '/Users/sebastiancruz/.qgis/python/plugins/fTools/
>> tools']
>> This is a message I get when I start up QGIS. The problem seems to
>> be GDAL mostly, which relates to the message I sent you earlier.
>> But overall I think the problem radicates in Python. In terminal I
>> can prompt Python 2.5 and make simple tests (2+2=4) witthout a
>> problem. But for example when trying to install Numpy from a
>> binary, it says it cannot detect python 2.5 in my system. Do you
>> think an upgrade would work?
>> I am sorry to keep bothering you with questions, but I really want
>> this work.
>> Sebas
>> On 15 Jul 2009, at 16:49, John C. Tull wrote:
>>> I'm afraid I can be of no help here. This is not anything I've
>>> ever encountered.
>>> Sorry,
>>> John
>>> On Jul 15, 2009, at 3:25 PM, Sebastian Cruz wrote:
>>>> Hi John,
>>>> Thank you for the lenthgy email you sent me. You are correct, I
>>>> have not set up the environment. I followed your recomendations
>>>> but encountered yet another problem. When trying to communicate
>>>> with GDAL, I get the following message:
>>>> /Library/Frameworks/GDAL.framework/Versions/1.6/GDAL ; exit;
>>>> sebastian-cruzs-macbook:~ sebastiancruz$ /Library/Frameworks/
>>>> -bash: /Library/Frameworks/GDAL.framework/Versions/1.6/GDAL:
>>>> cannot execute binary file
>>>> logout
>>>> [Process completed]
>>>> I do not know why the binary is having this problem. I had the
>>>> same issue instally rpy2 from terminal, with install sudo
>>>> easy_install -U rpy2.
>>>> (zip_safe flag not set; analyzing archive contents...
>>>> No eggs found in /tmp/easy_install-fULGJF/rpy2-2.0.6/egg-dist-tmp-
>>>> Ddqx_x (setup script problem?)
>>>> My python is 2.5, that came witht he MacoSX operating system. I
>>>> have not installed any other version.
>>>> Something is wrong with my system it appears.
>>>> Sebastian
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090715/3793d6f9/attachment.html>
