Error loading HomeRange plugin on Mac OSX[was: Re: [Qgis-user] Fwd: Hello,]
Anne Ghisla
a.ghisla at gmail.com
Thu Jul 16 01:53:19 PDT 2009
Il giorno mer, 15/07/2009 alle 22.20 -0600, Sebastian Cruz ha scritto:
> Begin forwarded message:
> > From: "John C. Tull" <john.tull at wildnevada.org>
> > Date: 15 July 2009 22:10:47 GMT-06:00
> > To: Sebastian Cruz <cruz.seb at gmail.com>
> > Subject: Re: Hello,
> > Sebastian,
> > I'm really not much better (any?) at figuring this stuff out than
> > you. I don't know why python would not be detected. Can you run
> > python from the terminal? If so, try a command like 'import rpy2'
> > and see what happens. Same with other modules you need.
> > Frankly, the homerange plugin never quite worked for me on OS X. I
> > think it did for a while, then did not. I'm not sure why, and I gave
> > up. You may also look at the manageR plugin, but you will have to
> > learn R commands for doing your analyses. R is a great program, and
> > you can get the binary online. In fact, you should already have it
> > to get rpy2 working (I think). Don't forget, rgdal is available from
> > William's site as a binary. I assume you tried that.
> > I would encourage you to contact the dev of the plugin if none of
> > the above helps. They are better at reading those outputs than I am.
Hi Sebastian,
first I apologise for lack of testing on Mac.
This error log is not telling so much about the source of the error...
Anyway, check if you have installed the correct version of the plugin:
for QGIS <1.0, use HomerangePlugin v1.x, for QGIS >=1.0, v2.x. Using
Faunalia 3rd party repository, the correct version only will be
available via Fetch Python Plugins.
I suggest also to check all dependencies and compatibility. On the wiki
page [0] there is a list of tested configurations.
As a final check, following John's suggestion, try importing manually
the modules in QGIS Python shell.
<code>
import rpy2.robjects as robjects
import rpy2.rpy_classic as rpy
</code>
and report on Animove Trac [1] any further problem.
The dependency check is left to the user at the moment - if anyone has
some idea about how to automate it, they are most welcome.
I can also tell you that manageR has very similar dependencies, so
making it work will also affect HR plugin.
BTW, if anyone has a running configuration for HomeRange plugin on Mac,
it would be nice to report all useful details and add them into the wiki
page :)
hope this helps and best regards,
Anne
[0] http://wiki.qgis.org/qgiswiki/GSoC2008Rbinding - will be moved on
new wiki http://www.qgis.org/qgis-wiki/ asap
[1] https://faunalia.it/animove/trac
> > Best,
> > John
> > On Jul 15, 2009, at 8:19 PM, Sebastian Cruz wrote:
> > > Hi John,
> > > I have to say I am not surprised by your reaction to the email I
> > > sent you, I also cannot make any sense out of it (and I know very
> > > little compared to you). I was wondering if the following messages
> > > makes more sense to you:
> > > Couldn't load plugin "HomeRange_plugin" from
> > > ['/Applications/Qgis.app/Contents/MacOS/share/qgis/python',
> > > '/Users/sebastiancruz/.qgis//python/plugins',
> > > '/Applications/Qgis.app/Contents/MacOS/share/qgis/python/plugins',
> > > '/Library/Frameworks/GDAL.framework/Versions/1.6/Python/site-packages', '/Library/Python/2.5/site-packages/SQLObject-0.10.6-py2.5.egg', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python25.zip', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-dynload', '/Library/Python/2.5/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/PyObjC', '/Users/sebastiancruz/.qgis/python/plugins/fTools/tools']
> > > This is a message I get when I start up QGIS. The problem seems to be GDAL mostly, which relates to the message I sent you earlier. But overall I think the problem radicates in Python. In terminal I can prompt Python 2.5 and make simple tests (2+2=4) witthout a problem. But for example when trying to install Numpy from a binary, it says it cannot detect python 2.5 in my system. Do you think an upgrade would work?
> > > I am sorry to keep bothering you with questions, but I really want
> > > this work.
> > > Sebas
> > > On 15 Jul 2009, at 16:49, John C. Tull wrote:
> > > > I'm afraid I can be of no help here. This is not anything I've
> > > > ever encountered.
> > > > Sorry,
> > > > John
> > > > On Jul 15, 2009, at 3:25 PM, Sebastian Cruz wrote:
> > > > > Hi John,
> > > > > Thank you for the lenthgy email you sent me. You are correct,
> > > > > I have not set up the environment. I followed your
> > > > > recomendations but encountered yet another problem. When
> > > > > trying to communicate with GDAL, I get the following message:
> > > > > /Library/Frameworks/GDAL.framework/Versions/1.6/GDAL ; exit;
> > > > > sebastian-cruzs-macbook:~ sebastiancruz
> > > > > $ /Library/Frameworks/GDAL.framework/Versions/1.6/GDAL ; exit;
> > > > > -bash: /Library/Frameworks/GDAL.framework/Versions/1.6/GDAL:
> > > > > cannot execute binary file
> > > > > logout
> > > > > [Process completed]
> > > > > I do not know why the binary is having this problem. I had the
> > > > > same issue instally rpy2 from terminal, with install sudo
> > > > > easy_install -U rpy2.
> > > > > (zip_safe flag not set; analyzing archive contents...
> > > > > No eggs found
> > > > > in /tmp/easy_install-fULGJF/rpy2-2.0.6/egg-dist-tmp-Ddqx_x
> > > > > (setup script problem?)
> > > > > My python is 2.5, that came witht he MacoSX operating system.
> > > > > I have not installed any other version.
> > > > > Something is wrong with my system it appears.
> > > > > Sebastian
> Qgis-user mailing list
Desc: Questa รจ una parte del messaggio firmata digitalmente
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090716/db169ad6/attachment.sig>
