[Qgis-user] RE: [Qgis-developer] New snapshot of OpenStreetMap	plugin
    Standaert Arnout
    arnout.standaert at vito.be
    Tue Jun  9 03:25:42 PDT 2009
A few questions relating to the OSM plugin... I'm trying to use it on Qgis 1.1.0 unstable (Pan), based on revision 10748.
When trying to load OSM data from a file, I get this error: "You don't have OSM provider installed!".
I suppose this is a problem with the unstable build I'm using? It probably hasn't been compiled with OSM provider support in it?
Is there a 1.1 unstable build somewhere that does have it?
A second question: apparently, the OSM data download feature does not use the proxy information in the general Qgis options. Or at least, even with the proxy configured in Qgis, the plugin just downloads the proxy's HTML error page instead of the real OSM data :-) Is this an error, or is proxy support not enabled in the plugin itself? (yet?)
In any case, thanks a bunch for all the effort put into this. Working with Qgis really helps our research over here!
Kind regards,
Arnout Standaert
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org
> [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of
> Martin Dobias
> Sent: maandag 1 juni 2009 14:59
> To: qgis-user; qgis-dev
> Subject: [Qgis-developer] New snapshot of OpenStreetMap plugin
> Hi all,
> for those interested in the QGIS-OSM integration, there's a
> good news: today the qgis-mapper team is releasing a new
> snapshot for public testing.
> Features:
> - download OSM data
> - load and display .osm files
> - identify nodes, ways and relations
> - edit data: create, modify, delete objects
> - upload changes to OSM server
> - automatic pre-defined styles for OSM data
> How does it look like:
> http://mapserver.sk/~wonder/qgis/qgis-openstreetmap.png
> (showing OSM data in center of Prague)
> Currently there is virtually no documentation available for
> usage of the plugin. This will be fixed in the following weeks.
> We welcome any comments, suggestions or bug reports from you!
> Hopefully at some point of time in future this work will be
> integrated into QGIS codebase. Currently it's necessary to
> install provider separately.
> == Installation ==
> Requirements: you need QGIS sources, at least v1.0.0,
> preferably SVN trunk.
> 1. download OSM provider:
> http://mapserver.sk/~wonder/qgis/osm_provider-snapshot-090601.tar.gz
> 2. unpack to source into src/providers/
> 3. modify src/providers/CMakeLists.txt - add "osm" to the
> list of subdirectories
> 4. recompile and install qgis
> 5. using plugin installer, fetch the "OpenStreetMap plugin"
> from my repository:
> http://mapserver.sk/~wonder/qgis/plugins-sandbox.xml
> 6. restart qgis and you're ready for street mapping!
> Regards
> Martin
> Qgis-developer mailing list
This e-mail, any attachments and the information it contains are confidential and meant only for the use of the addressee(s) only.  Access to this e-mail by anyone other than the addressee(s) is unauthorized.  If you are not the intended addressee (or responsible for delivery of the message to such person), you may not use, copy, distribute or deliver to anyone this message (or any part of its contents) or take any action in reliance on it.  In such case, you should destroy this message and notify the sender immediately.  If you have received this e-mail in error, please notify us immediately by e-mail or telephone and delete the e-mail from any computer.
All reasonable precautions have been taken to ensure no viruses are present in this e-mail and its attachments.  As our company cannot accept responsibility for any loss or damage arising from the use of this e-mail or attachments we recommend that you subject these to your virus checking procedures prior to use.
