[Qgis-user] DNG and printing maps
Bernhard Ströbl Bernhard.Stroebl at jena.de
Mon Jun 15 00:19:56 PDT 2009
Hi Einar,
afaik only DGN from pre V8-Microstation is supported by ogr. V8 was
introduced in 2004 so it is very likely that your data are not supported
by ogr. If you have Microstation software available I could provide you
with a VBA-script that converts dgn to shp.
Bernhard
Andreas Neumann schrieb:
> Hi Einar,
> DGN should work through the open vector dialogue (provided by OGR). The
> newer QGIS releases (I think 1.1. or later) feature a more sophisticated
> vector data loader.
> Did you try through the vector data loader?
> Andreas
> PS: see http://www.gdal.org/ogr/drv_dgn.html for some details on the ogr
> dgn provider
> On Fri, June 12, 2009 8:49 pm, Einar Guðsteinsson wrote:
>> hehe
>> I did mean DGN, I am photosgrapher as hobby and used DNG there. :)
>> Einar
>> From: "Andreas Neumann" <a.neumann at carto.net>
>> Sent: Friday, June 12, 2009 5:55 PM
>> To: "EinarGuðsteinsson" <einsigu at simnet.is>
>> Cc: <qgis-user at lists.osgeo.org>
>> Subject: Re: [Qgis-user] DNG and printing maps
>>> Hi,
>>> currently the print-composer cannot split the print output to multiple
>>> pages. You can export the map to a tiff or pdf file. I would recommend
>>> using a PDF viewer or graphics tool to do the split up/multipage
>>> printing.
>>> regarding DNG: do you really mean DNG (the Adobe digital negative photo
>>> format?) - this is not a common GIS format at all since it doesn't
>>> support
>>> georeferencing (as far as I know).
>>> Or do you mean DGN, the microstation CAD format? this should be
>>> supported
>>> through OGR (vector layer).
>>> Andreas
>>> On Fri, June 12, 2009 7:40 pm, Einar Guðsteinsson wrote:
>>>> Hey
>>>> I have two proplems. First one. I have made this fine map. Now I would
>>>> realy like to print it. I need to split it up on few pages. Is there
>>>> some
>>>> easy way I can do that?  Export it as photo or pdf. I was trying to use
>>>> print composer but did not see how I could split all the map on pages.
>>>> The other thing is may be not Qgis thing but is there way to open DNG
>>>> files or convert them to something Qgis can read?
>>>> Best regards
>>>> Einar G._______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Andreas Neumann
>>> http://www.carto.net/neumann/
>>> http://www.svgopen.org/
Dipl.-Geogr. Bernhard Ströbl
Anwendungsbetreuer GIS
Kommunale Immobilien Jena
  - Datenverarbeitung -
mailto:Bernhard.Stroebl at jena.de
http://kij.jena.de/
________ Information from NOD32 ________
This message was checked by NOD32 Antivirus System for Linux Mail Server.
http://www.nod32.com
