[Qgis-user] DNG and printing maps
    Andreas Neumann
    a.neumann at carto.net
    Fri Jun 12 19:54:14 PDT 2009
Hi Einar,
DGN should work through the open vector dialogue (provided by OGR). The
newer QGIS releases (I think 1.1. or later) feature a more sophisticated
vector data loader.
Did you try through the vector data loader?
Andreas
PS: see http://www.gdal.org/ogr/drv_dgn.html for some details on the ogr
dgn provider
On Fri, June 12, 2009 8:49 pm, Einar Guðsteinsson wrote:
> hehe
> I did mean DGN, I am photosgrapher as hobby and used DNG there. :)
> Einar
> From: "Andreas Neumann" <a.neumann at carto.net>
> Sent: Friday, June 12, 2009 5:55 PM
> To: "EinarGuðsteinsson" <einsigu at simnet.is>
> Cc: <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] DNG and printing maps
>> Hi,
>> currently the print-composer cannot split the print output to multiple
>> pages. You can export the map to a tiff or pdf file. I would recommend
>> using a PDF viewer or graphics tool to do the split up/multipage
>> printing.
>> regarding DNG: do you really mean DNG (the Adobe digital negative photo
>> format?) - this is not a common GIS format at all since it doesn't
>> support
>> georeferencing (as far as I know).
>> Or do you mean DGN, the microstation CAD format? this should be
>> supported
>> through OGR (vector layer).
>> Andreas
>> On Fri, June 12, 2009 7:40 pm, Einar Guðsteinsson wrote:
>>> Hey
>>> I have two proplems. First one. I have made this fine map. Now I would
>>> realy like to print it. I need to split it up on few pages. Is there
>>> some
>>> easy way I can do that?  Export it as photo or pdf. I was trying to use
>>> print composer but did not see how I could split all the map on pages.
>>> The other thing is may be not Qgis thing but is there way to open DNG
>>> files or convert them to something Qgis can read?
>>> Best regards
>>> Einar G._______________________________________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Andreas Neumann
>> http://www.carto.net/neumann/
>> http://www.svgopen.org/
Andreas Neumann
