[Qgis-user] DNG and printing maps
Einar Guðsteinsson
einsigu at simnet.is
Fri Jun 12 11:49:19 PDT 2009
hehe
I did mean DGN, I am photosgrapher as hobby and used DNG there. :)
Einar
Sent: Friday, June 12, 2009 5:55 PM
To: "EinarGuðsteinsson" <einsigu at simnet.is>
Cc: <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] DNG and printing maps
> Hi,
> currently the print-composer cannot split the print output to multiple
> pages. You can export the map to a tiff or pdf file. I would recommend
> using a PDF viewer or graphics tool to do the split up/multipage printing.
> regarding DNG: do you really mean DNG (the Adobe digital negative photo
> format?) - this is not a common GIS format at all since it doesn't support
> georeferencing (as far as I know).
> Or do you mean DGN, the microstation CAD format? this should be supported
> through OGR (vector layer).
> Andreas
> On Fri, June 12, 2009 7:40 pm, Einar Guðsteinsson wrote:
>> Hey
>> I have two proplems. First one. I have made this fine map. Now I would
>> realy like to print it. I need to split it up on few pages. Is there some
>> easy way I can do that? Export it as photo or pdf. I was trying to use
>> print composer but did not see how I could split all the map on pages.
>> The other thing is may be not Qgis thing but is there way to open DNG
>> files or convert them to something Qgis can read?
>> Best regards
>> Einar G._______________________________________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
