[Qgis-user] raster catalog: qtsql?
John C. Tull
john.tull at wildnevada.org
Mon Jun 15 19:34:56 PDT 2009
To answer for Agus, I tried this on my ubuntu linux vm and the plugin
still shows up as not-compatible.
I was poking around in the plugin source and it looked like there may
have been some things, like a path for the plugin icon, hard coded to
a path on a Windows machine. I may be way off here (likely), but I
wonder if some code generalization is needed for compatibility on
other platforms.
Cheers,
John
On Jun 15, 2009, at 7:00 PM, Alex Mandel wrote:
> Hmm, maybe they aren't included in python-qt4 Ubuntu seems to have a
> python-qt4-sql package, try that.
> Alex
> Agustin Lobo wrote:
>> Thanks,
>> I meant that I already had
>> python-qt4 4.3.3.2
>> libqt4-sql 4.4.0
>> installed.
>> After your message, I installed
>> libqt4-sql-psql
>> libqt4-sql-sqlite
>> libqt4-sql-odb
>> but still was geting the same message in qgis:
>> "The plugin depends on some components missing on your system. You
>> need
>> to install the following Python module in order to enable it: QtSql"
>> I've now installed
>> python-qt4-sql
>> and finally could install the plugin. Nevertheless, after restart,
>> the
>> plugin is greyed as incompatible in the plugin manager.
>> I'm using Qgis 1.1.0 Pan Uunstable)
>> Thanks
>> Agus
>> Andreas Neumann wrote:
>>> You need both.
>>> libqt4-sql is for C++ and also the foundation for other script
>>> bindings
>>> like python (correct me if I'm wrong).
>>> python-qt4 are the python bindings for Qt4, it includes qtsql
>>> bindings.
>>> You probably also need one of the following packages:
>>> libqt4-sql-psql (Postgres support)
>>> libqt4-sql-sqlite (SQlite 3 support)
>>> or any other db you want to support.
>>> Andreas
>>> On Mon, June 15, 2009 8:17 am, Agustin Lobo wrote:
>>>> I've tried to install (on qgis 1.1.0) the raster catalog plugin
>>>> and I 'm
>>>> told
>>>> that Qtsql is required, but which package exactly? According to
>>>> Synaptic I have python-qt4 4.3.3.2 and libqt4-sql 4.4.0
>>>> Thanks
>>>> Agus
> Qgis-user mailing list
