[Qgis-user] raster catalog: qtsql?
Agustin Lobo
alobolistas at gmail.com
Mon Jun 15 23:16:54 PDT 2009
Alex,
I already had installed both python-qt4 and python-qt4-sql,
I can install the plugin with no error messages, but it shows
up as incompatible in the plugin manager once
installed and qgis restarted.
Agus
(is the author JJL listening this list? Could not find any message from
him/her
and cannot cc)
Alex Mandel wrote:
> Hmm, maybe they aren't included in python-qt4 Ubuntu seems to have a
> python-qt4-sql package, try that.
> Alex
> Agustin Lobo wrote:
>> Thanks,
>> I meant that I already had
>> python-qt4 4.3.3.2
>> libqt4-sql 4.4.0
>> installed.
>> After your message, I installed
>> libqt4-sql-psql
>> libqt4-sql-sqlite
>> libqt4-sql-odb
>> but still was geting the same message in qgis:
>> "The plugin depends on some components missing on your system. You need
>> to install the following Python module in order to enable it: QtSql"
>> I've now installed
>> python-qt4-sql
>> and finally could install the plugin. Nevertheless, after restart, the
>> plugin is greyed as incompatible in the plugin manager.
>> I'm using Qgis 1.1.0 Pan Uunstable)
>> Thanks
>> Agus
>> Andreas Neumann wrote:
>>> You need both.
>>> libqt4-sql is for C++ and also the foundation for other script bindings
>>> like python (correct me if I'm wrong).
>>> python-qt4 are the python bindings for Qt4, it includes qtsql bindings.
>>> You probably also need one of the following packages:
>>> libqt4-sql-psql (Postgres support)
>>> libqt4-sql-sqlite (SQlite 3 support)
>>> or any other db you want to support.
>>> Andreas
>>> On Mon, June 15, 2009 8:17 am, Agustin Lobo wrote:
>>>> I've tried to install (on qgis 1.1.0) the raster catalog plugin and I 'm
>>>> told
>>>> that Qtsql is required, but which package exactly? According to
>>>> Synaptic I have python-qt4 4.3.3.2 and libqt4-sql 4.4.0
>>>> Thanks
>>>> Agus
> Qgis-user mailing list
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090616/4e3a2555/attachment.vcf>
