[Qgis-user] problem
Giovanni Manghi
giovanni.manghi at gmail.com
Sun Jun 21 08:41:25 PDT 2009
On Sun, 2009-06-21 at 17:28 +0200, Vladimír Nemček wrote:
> Hello,
> I am new on this mailing list and I have a problem with home range
> plugin.
> Home range plugin write this error: Unable to determine R version from
> registery. Calling the command R RHOME does not return anything. This
> might be because R.exe is nowhere in your Path.
> Thanks for answer,
The message is pretty clear, after installing R, you need to add the
path to the R binary in the path variable of your windows installation.
-- Giovanni --
