[Qgis-user] Segmentation fault
Christy Nieman cnieman at dmsolutions.ca
Mon Jun 22 11:41:35 PDT 2009
Did you happen to have a Qt update recently?  This caused grief for me
for quite a while:
http://forum.qgis.org/viewtopic.php?f=3&t=4335#p8204
Just a thought.
Christy
Evert Groenewald wrote:
> I have the latest Qgis installed, version 1.1.0-2.11 from the openSuse
> 11.1 x86_64  repos. When starting qgis the splash screen appears and
> then nothing. When starting from the command line with the command
> "qgis" it simple states "Segmentation  fault" and stops.
> evert at linux-inzk:~> qgis
> Segmentation fault
> I've removed qgis and its configuration files, reinstalled all with the
> same results. Could it have something to do with the python version?
> Installed  version is python 2.6.0-2.21.1 . I know that at some point a
> python upgrade was incompatible with the qgis installation on openSuse
> 11.1  .
> Will appreciate any help.
> Thanks
> evert
> Qgis-user mailing list
