[Qgis-user] Importing USGS DEMs
    John C. Tull
    john.tull at wildnevada.org
    Sat Jun 27 13:25:21 PDT 2009
Works fine for me. The link should have a lower case 'f' in the file
name. You need to uncompress the file before trying to use it in qgis,
but if you have gdal compiled with dem support, you should be good to
go.
John
On Jun 27, 2009, at 1:12 PM, Brook Milligan wrote:
> I am having trouble importing USGS DEMs into qgis.  One example of a
> problem file is at:
> 	http://rgisedac.unm.edu/elevation/dem10m/32105F5dem.zip
> How should this type of file be handled in order to successfully
> import it?
> Thanks for your help.
> Cheers,
> Brook
> Qgis-user mailing list
